Right, an update on my original query that I could use some help / advice on.
I've driven my Panda over a couple of hundred miles in the last few days and I'm not sure if the Dualogic gearbox system is working properly or not. I'll explain what I've noticed, and as not having driven a Dualogic before, am hoping someone can enlighten me a bit.
Firstly, the hydraulic actuator pump seems to be running for quite a long time when I open the drivers door, I would say generally between 10 - 15 seconds, and I have noticed that while driving along, the pump can be heard running now and again, but not for long, only a few seconds. I have checked battery and alternator charge / operation, and these are fine.
Next, no matter how I operate the accelerator to drive off from stationary I still get some juddering, with different degrees of severity. After driving for 15 - 20 minutes the juddering stops and my Panda pulls away from stationary nice and smooth.
Also, some gear changes can be very jerky, but not all. For example, I notice it more when the car has to change down gears when going up an incline, also gear changes under hard acceleration can be jerky too.
Finally, while driving with the windows down most, if not all, gear changes produce quite a pronounced metallic click / clunk sound. With the windows up the sound cannot be heard.
The general running of the car is fine, I'm not getting any warning lights so have no idea if what I've noticed is normal or not. My local Fiat dealer has said that they are quite willing to have a technician take it for a drive and see what he thinks, thing is that by the time I get there, the car will run fine. Also, this is not the dealer where I bought the Panda and where the warranty is in place, so if there are any issues with the Dualogic, I really need the dealer I bought the car from to sort any issues out under the warranty, if in fact there are any problems. I still don't know if I'm driving the Panda correctly, so this could still be the cause of many of the things I've noticed.
Any thoughts, views and advice on this would be greatly appreciated.
