Just Joined to say thanks to forum and previous posters on this topic...the posts led me in the right direction and I have working wipers.
If you have failing wipers you MUST first remove the wiper arms. Remove the three crosshead screws and the black plastic cover at the bottom of the windscreen. The cover has hidden (plastic!) clips - slide it 'down' slightly to unhook them, then lift from the bottom and manoeuvre it off.
Unplug the wiring from the wiper motor (Ignition is OFF, Right?) Undo the two bolts and remove the wiper assembly. Take it inside, out of the rain...
The socket is on a plastic cover that unclips and lifts off...careful with those clips! Inside you will find electrical 'brushes and another 2 connectors...look carefully at the plastic post with a brassy strip over it...that is the earth connection and mine was dodgy. While there clean everything, then gently squeeze open connectors closed and the brassy strip open so it will contact the metal wiper motor housing firmly.
Reassemble install (just the motor), and test
IF you've read this and do it you are likely to repair your wipers without needlessly searching for the clicking 'relay (it's not a relay it's a ***** Body Control Computer) or removing your indicator stalks to test them, or learning fiat yoga position 437A (access and test wiper wiring) OR having to realise that the reason you see voltage for a second only at the wiper plug is because the effing computer is sensing a fault and switching off the voltage and the switches and relays are perfect!!!!!!
As I said...the previous posts I found gave me good clues - and I am grateful for them. I hope this one helps a few. If it clicks (said a previous poster) The Switch and the Computer are probably OK.
John
John
