I wonder if someone with multiecuscan can log the voltage when they first crank the car over. Even after a drive mine drops down to 9.6 volts as its cranking. I would expect it to drop to around 10v. Could just the way the ECU is measuring it. Just need something to compare with
When I first got the car in August the power steering cut out a few times. Seem to fix itself. Recently its done it a few times again. Suspect the car may have stood awhile and the battery was week when I bought it and now its colder its showing up a weakness in the battery.
Thanks in advance
Thanks in advance
