To all Panda owners reading this, take a look at your 'Coolant Outflow Pipe'.
It runs from the left side of your engine where the water pump is, under the exhaust manifold and out to the right onto a rubber flexible hose.
You may discover that the black paint finish of this steel pipe has rotted and if you do, you should replace it to avoid further problems at a bad time.
The part photographed is £40 from FIAT, and interestingly, the one you buy today is a 'revised' part from the original hinting at a recognised weakness perhaps in the original.
We fitted this in 20 minutes and you DO NOT need to remove the exhaust manifold, just the heat cover over it. Do not let a mechanic tell you this will take hours and needs removed or that you're better to leave it..
Mines developed a huge GASH and eventually squirted Coolant out in your face!!! Not good for you, or the car! If you run the car with no Coolant then it won't take long to utterly destroy the engine due to overheating and leave you stranded with an 850kg paperweight on wheels.
Two clips on each end (20.5mm and 23mm respectively) and the third part pushes into the engine and comes with a seal.
I am using information the forum gave me in order to do this, and reminding you to check for this problem in advance as not so long ago it was an issue for me, and had it burst whilst driving I may not have my car in good shape or working condition. Thanks to everyone who has helped me on this one a few weeks ago.
Hope this helps someone and if you need any help I am now able to help
Part number can be seen in photos as well as the part itself.
