- Sep 14, 2009
- 19,492
- 3,294
I know the ideal solution is a new (used) rear axle but it looks like mine is fixable before its too late. A new axle is not low cost and Pandas hard to come by so I want alternative options.
The rear shock inner bracket is welded to the coil spring pan. Mine (both sides) are rotting but the spring pans still look ok.
Has anyone weld repaired a rusting rear axle? Does reinforcing that shock bracket keep the spring pan in place?
As an alternative will the Fiat 500 axle (drum brake) swap straight over to the 2003-2010 Panda?
