Thread Tools
Old 27-03-2016   #1
Problem fitting a power socket
I am trying to fit a power socket to panda 1100. There is a plug under the handbrake console, i fitted a relay and fuse in appropriate slots in main box under bonnet, no power.
Have now u nloosed the fuse 'box' under bonnet and spoted there is no lead going to fuse 85 or to relay 31
Shouild there be leads somewhere waiting to be connected ?
jim mac is offline Reply With Quote Quote
Old 29-03-2016   #2
Goudrons has donated!
Re: Problem fitting a power socket
It's common on the Active models to have the wiring, but not the socket it's self and some find the loom doesn't seem to connect to anything, power wise, some other do!
I think they fitted a standard wiring loom, but the fuse boxes were different between models.
Unless you can find the end of the lead and connect it up to another switched live fuse within the box, you'd probably find it easier to run another wire to it.
Use a fuse tap on another switched live fuse. (see handbook for which to tap)
I think the earth should be ok at the connector, but it's worth testing it.
Goudrons is offline Reply With Quote Quote
Thread Tools
(T) Power socket adeverett Qubo 2 13-04-2014 09:54
(T) Boot power socket adeverett Qubo 5 18-08-2013 21:06
(T) Fitting 12v socket to Panda yowe6 Panda 0 26-05-2011 19:03
(T) !2 volt power socket. Wurn Ducato 0 06-08-2009 12:48
(G) car power socket ayresm 500 1 10-07-2009 22:04
