So guys, I've noticed my gears aren't quite right. Whether due to age/wear or mis-used over time I don't know.
I also don't know if it's okay to continue to use them over the next year, or to add it to my essential list of repairs I'm saving up for, so I'm going to describe this the best I can.
The car NEVER slips 'out' of gear, and when I do eventually get the stick to slot into the desired gear, they function fine..
First Gear / Start Off
Getting into first can be a struggle, I put the clutch in, gently push it left and up for one. Now. It goes left, and up, but it doesn't go in naturally. I find myself 'wriggling' it left and right whilst pushing forward and it finally 'finds' the gear slot. I then need some force to push it in. Once in, first gear works fine.
Additionally, when the car is fully loaded or under strain from multiple fully grown adults, pulling off, especially on hills causes a grind noise. I've mentioned this a few times, not sure if it's a gear problem, structural problem or what yet but mentioning it in case it's related.
Second Gear
It's also the same story with 2nd. Especially going down from third in city driving and down from one when starting. The gear stick feels loose, like it's so prone to 'missing' the slot the gear stick should slot into when 2nd is engaged. It's fiddly to force it in, and it does, just like first, require a bit of force to get it into gear. Once in, second functions fine. This is the real power / eager gear on the 1.2 petrol! I love it too!
Third Gear
Third is fine, but getting it in probably isn't as precise as it should be. Requires a little bit of force, but not as much as 1 and 2. Third gear works fine when engaged.
Fourth and Fifth
Absolutely No problems, easy enough to engage.
REVERSE
Reverse is a problem too. When I start the car and engage reverse, I pull up the syringe mechanism firmly and fully up, and proceed to move the gear right and toward the rear. As the gear engages, I hear a loud 'CRUNCHHHH' which quickly slows and then when reverse is engaged it works fine. But sometimes, it feels like it's slipping. E.g. The car WILL reverse, but I know as I step on the gas it's getting half the power, then I discover it's not quite fully in. So I have to disengage and re-engage MORE firmly which also feels like it's not normal. The car reverses fine when reverse is engaged correctly. But there is hassle getting there. I've reversed it the whole way up my street and nothing unusual except that whine cars do in reverse that sounds like a motor.
Really hoping this is some kind of linkage or gear selector problem, as I'd imagine big transmission issues are expensive and a reason to 'move on' to another car. <- really don't want to move on. I want this Panda until the day it looks as out of place as the 1990 Ford Orion on my street alongside my shiny new one! haha
Previous owner was my sister who before the Panda drove a 2.5L Mitsubishi Shogun ... Strong feeling it was her forcefulness that hurt my Panda's gear :-/ At first I thought I was getting used to it, but now I'm sure it's not right. I don't think Fiat checked this in the service either, wish I had have asked them but!
Thanks guys!
Second Gear
Third Gear
Fourth and Fifth
REVERSE
Thanks guys!
