Old 24-03-2016   #1
Panda 100K+ club
Louie Bee's Avatar
Trader Rating: 9
Louie Bee has donated!
Rollin X Pinball Champion, Bubble Bobble Champion
Mozambique
Front shock bearing
Had a thumping clonking noise when turning the steering wheel.
When turning the shock top bolts by a socket to spin the piston I noticed the top of the N/S spring was catching at the top then bouncing round, causing the noise.
Good to find the top bearing not a FIAT only part... most other MJ parts I need seem to be
Will post some pics in a min.
Louie Bee is offline Reply With Quote Quote
Old 24-03-2016   #2
Panda 100K+ club
Louie Bee's Avatar
Trader Rating: 9
Mozambique
Re: Front shock bearing
Here we go
New part
Shock off
I hate this bit
Locked old and new 19mm nuts to help keep the piston still to remove the 27mm nut
Nice gap - no spring tension
and it's off
side by side
Well messy - bearing won't move.
Nice and new - smooth as can be
On it goes
Starting to feel safe when this nut goes on, but don't like playing with spring clamps
All off - just need to pop back on the car.
Old 24-03-2016   #3
Panda 100K+ club
Louie Bee's Avatar
Trader Rating: 9
Mozambique
Copper spray was an attempt to get the bearing / spring slipping while I waited for the new part.
It Made little difference
All finished by bed time and no clonking noise today - smooth stearing again
Old 24-03-2016   #4
Panda Fanatic
SB1500's Avatar
SB1500 has donated!
Thanks for sharing!
I just re-did my two front struts, springs, strut mount and bearings on my 1.2 Petrol. I did notice the parts varied for the different Diesel engine! :-)
Wish I had of photographed it as well as you, however!
2017 DS3 Prestige 1.6 BlueHDI 120 - 18,600 miles [20-]
2017 Fiat Panda Easy 1.2 - 34,400 miles [19-20]
2005 Fiat Panda Dynamic 1.2 - 153,700 [15-19]
SB1500 is offline Reply With Quote Quote
Old 24-03-2016   #5
Panda 100K+ club
Louie Bee's Avatar
Trader Rating: 9
Mozambique
Did my front shocks 2.5 year ago after a pot hole run in
Looking back I should have done the bearings too
I didn't look up the parts - I just ask my local motor factors and they rarley get it wrong.
Took about 3 hours last night... think that's why I often don't bother with pictures as it seems to add in a lot of time... maybe not helped by not keeping a tidy tool box and working by lamp
Old 29-03-2016   #6
Panda 100K+ club
Louie Bee's Avatar
Trader Rating: 9
Mozambique
Seem to have a very slight knocking over bumps on the N/F/F
Maybe like the drop link is on its way out after being removed and put back.
Also the power steering has tripped off a couple of times since I did the bearing.
Also on the new bearing side I noticed less strut top sticking through and a smaller gap under between top plates to inner wing. think the new one is slightly thicker.
Guess I'll have to do the driver’s side too to even them up.
Just seen your thread SB1500. What a mission getting them bits! My motor factor is a FIAT enthusiast and tries really hard to get bits for me. Even checks a copy of the EPER to get the FIAT part number and crossref aftermarket alternatives if stuck.
Known him since we both had Unos – Just about the last ones on the road in this town – top guy.
(T) Front Shock Replacements Bundutoe Panda 1 28-09-2014 17:31
(G) Front Shock's theviper Punto (Mk2/2b) 2 23-08-2007 11:41
Front shock absorbers julian FIAT Boo Archives 1 17-05-2006 00:34
Front shock MP FIAT Boo Archives 7 22-12-2004 19:01
