not TOO complicated.. but you don't NEED to change it
all the non HP pandas are 8 Valve, but the later ones have tighter clearances..which means they are like "normal" engines, belt failure means valves dangling into the cylinder and the piston crown hitting them
the early 8V is a "safe" engine.. - if a belt breaks it's unlikey to do ANY damage, just fit a new belt..and normal service is resumed
however you want to minimise the risk of belt failure,
IMHO the waterpump is going to leak water at the 1st sign of bearing wear,
just replace the belt and it's idler bearing, @£30 and an hour or so's labour:worship:
I'll attempt to find the pics for you, I listed the tools required,
15 and 16 sockets.., but if you did the front suspension you probably already have access to these
Charlie
Charlie
