I've tried and tried to get an aftermarket radio into the metal holding cage used by the original head unit (Blaupunt double din). The radio fits in and slides in fine, but it won't slide in far enough due to some cables between the Pioneer head unit and the cars connectors.
It's as if there's no room for this adapter to fit between the radio and the inside of the dash. But clearly, with the amount of people with aftermarket units there is a solution. Having sat for an hour, I can't find one :-(
I'm waiting for my fascia (cheap eBay one - couldn't find genuine). And getting a generic single din mounting bracket to hold the radio into the stock 'cage' that held the stock radio unit.
Worst of all, the little allen screw bolt with the rubber ring fell through the dash into some enclosed area and I don't know where to find it, it will be rolling loosely around in there. I'm worried it will jam something or get into the heater system :-( Think it'll need the dash taken apart somewhere but where?
Also, the Green/Yellow/Blue connector has no place to go, what did these cables function as for the Blaupunt unit?
Kind of annoyed, I'm in a worse position than I started with a lost screw and the original head unit.
