![]() | #1 | ||
Posts: 14 Thanks: 0 Trader Rating: 0 ![]() | Panda 1.2 Slave Cylinder Replacement Help Hi All I need to replace the clutch slave cylinder on my 2007 Panda 1.2 Dynamic, I have order and received the slave cylinder but cannot for the life of me figure out how the join in the pipe works as there does not seem to be a male and female portion to the connector? How does this disconnect? I have attached some images to help with my explanation. Thanks David
![]() | #2 | ||
Posts: 1,908 Thanks: 103 Trader Rating: 0 ![]() | Re: Panda 1.2 Slave Cylinder Replacement Help Hard to see as the image is so small, but no idea what that junction box is. If you're just changing the slave, don't you just unbolt it and then disconnect the 10mm feed pipe on the cylinder itself?
![]() | Eridanny | Bravo | 9 | 22-12-2013 22:25 |
![]() | Ramrodd | Grande Punto | 0 | 31-07-2013 17:43 |
![]() | lilman777 | Bravo / Brava | 6 | 14-10-2007 17:51 |
![]() | antsuno2 | Uno | 2 | 22-05-2007 05:55 |
Slave Cylinder | Barakka | FIAT Boo Archives | 5 | 26-03-2003 13:22 |
