Thread Tools
Old 18-01-2016   #1
Question Panda 2003-2012 Earthing Points
Does anyone please have a list of exactly where all the earthing ground points are on a 2003-2012 RHD Panda as the eLearn Manual Sketches are very vague and only pertain to LHD Cars. The ones that I am interested in are the internal ones as the engine bay points are mostly visible.
Likes Muddur liked this post
skydome is offline Reply With Quote Quote
Old 21-01-2016   #2
Panda Fanatic
SB1500's Avatar
SB1500 has donated!
Re: Panda 2003-2012 Earthing Points
Best I could do is look on eLearn too, but you say it's not clear enough?
Someone on here is bound to be able to describe in detail from experience, what is the nature of the problem so that they can assist in explaining the nearest / most suitable grounding point for you?
- thanks
2017 Fiat Panda Easy 1.2 - 29,550 miles
2005 Fiat Panda Dynamic 1.2 - 153,700
SB1500 is offline Reply With Quote Quote
Old 24-12-2019   #3
Denmark
Bump!
After finding several extra earthing wires for the rear lights in both sides and burned connectors , I are planning a minor wire-job in the comming spring.
So should anyone have pictures or sketches, I would be very greatful
BTW: Is it true that the original wire are so thin?
Panda Mk.II (169), 1.2L. 2005
Muddur is offline Reply With Quote Quote
Old 24-12-2019   #4
After problems with rear lights/wiper and power steering, I ran a couple of extra earth leads which cured the problems.
Rear Lights on disco setting / rear wiper footbrake operated :
Cured: original earth leads are well inboard and required removal of wheel arch carpets to reach. Easy option - tap in to earth lead on rear lamps and run a new lead to a screw hole drilled in tailgate aperature.
Power steering: Spurious problem with loss of assistance (new battery already).
Cured: Original body earth checked and cleaned below battery tray but no difference
New lead -4 Halfords- run from battery earth to n/s wing mounting bolt - problem disappeared. (No probs last 9 months)
Trimdoner is offline Reply With Quote Quote
Old 26-12-2019   #5
You cant have too many earth points. :-)
Run a heavy gauge from engine block to chassis.
Drill the rear light "chassis" to take self tapping screws and run earth wires from each side to self tappers screwed into the body shell. Resistance from each bulb housing to chassis should be near enough zero ohms. Ideally scrape away the paint under the ring tags using copper grease to protect the bare metal.
DaveMcT is online now Reply With Quote Quote
Thread Tools
(T) Earthing Points ? cyberscouse Bravo 5 01-01-2016 16:17
(T) cinquecento earthing points loserscar Cinquecento / Seicento 1 12-04-2015 01:45
(G) Earthing points? boddahchris Grande Punto 9 14-01-2009 11:15
(T) how many earthing points bulgarianbarchetta Barchetta 3 19-04-2008 19:34
(G) Earthing points Alan.D Panda (Classic) 2 27-01-2007 11:17
