MountainRunner
Member
- Aug 7, 2014
- 82
- 92
Hi
I have a 2007 fiat panda diesel multijet.
I thought I'd check my air filter to see if it needed changing. So removed the cover and noticed a few centimetres of the offside end of the paper filter was soaking wet, that end bit was also dirty. The rest was clean and dry.
We have had a lot of rain in the last few weeks but my obvious concern is that water could get into the engine and wreck the piston rods . Especially if this moisture in the filter condenses and is sucked into the engine air intake.
I have heard that water getting into the panda multijet Diesel engine is a known problem. There is a bolt just above the filter beneath the windscreen that leaks onto the filter housing but I've since covered it thickly in grease to stop any water.
The other possible problem is the air intake hose points directly to the front, so driving in very heavy rain could force water into the air filter.
Any suggestions?
Any suggestions?
