Hi out there.
Can any one help , I have a major leak on the metal coolant pipe of a 2006 1.1 active Panda. I took it off and it resembled a flute there were that may holes in it. So off I went to the fiat dealership bought a new one only to find it doesn't fit. the sleeve going into the water pump housing is 30mm and the replacement part is 35mm. The dealership assures me it is the right part but obviously not. the part number is 55245750, I have also tried part number 55185422 but that is the same.
I have bodged the old pipe with chemical metal and it is holding at the minute but not for long I suspect.
Has any one got any ideas
