billysally208
- Mar 24, 2015
- 12
- 3
Hi, 2004 Panda Dynamic non air con - heater fan only working on no.4 setting.
I know there are several previous posts on this - I have searched on here and on the inter web and even Pm'd another member who has offered some sound advice (Thank you @ portland_bill) but can anyone ( who has perhaps replaced theirs) on the Forum offer any advice on how to access the resistor pack. I had a go at the weekend - disconnected the steering column from the rack, removed the small lower footrest panel and unplugged the connecting plug from the resistor and tucked the wires out of the way. I can just about see the head of the single screw that holds it in place (which I have determined needs a 5.5mm socket) but cannot get anything on it to undo it. Did manage to get a 1/4" drive socket on but there is not enough room to undo it even at one click at a time.
Have considered removing the lower trim console but after talking to portland_bill he doesn't think this will help with the access issue.
Gave up after a couple of hours but will be having another go later this week - so any advice, other than whipping the doors off and removing the dash completely will be appreciated.
