Old 05-11-2015   #1
Question New clutch slave cylinder
Does anyone know how long it would normally take to change the clutch slave cylinder on a Fiat Panda 100HP?
Mine packed in (completely unable to select gear) so I booked it in and towed it into the local garage.
They've had it 2 days already now, and it won't be ready until tomorrow. They seem to be saying that something went wrong, and a pipe split and they're not able to give me any costs yet.
I think part of the time they've had it is probably waiting for parts to be delivered, but I'm slightly nervous that it's going to be quite expensive—anyone got any prices for comparison?
thesheep is offline Reply With Quote Quote
Old 05-11-2015   #2
Trader Rating: 1
portland_bill has donated!
Re: New clutch slave cylinder
Earlier this year I replaced the master and slave cylinders on the Panda, but this is a 1.2 engine. The slave is on top of the gearbox on mine, requiring the battery to be removed, then the battery carrier, which involves unclipping various cables, etc., that are attached. The whole job, both cylinders, including bleeding took about 2 hours.
The 1.4 engine obviously takes up more space, but this shouldn't cause much of an issue with accessing the clutch slave (unless anyone else knows different?).
The replacement slave includes its supply pipe. This attaches to the gearbox and joins to the pipe from the master cylinder. The connections are push-in with an 'O'-ring, held in by a tiny clip. If they've damaged the pipe to the slave, they could always use the old one.
When you collect it, be sure to ask lots of questions to get a detailed breakdown of the work done, and why it was necessary. Ask to see all replaced parts. If failure is due to damage during fitting, it is their responsibility, not yours. Unless of course, a split pips was actually the cause of the breakdown, not the slave cylinder. But let them tell you that without prompting from you.
Sadly, OE parts are expensive, but the slave from Euro is less than £20. I got a master cylinder from Ebay, about £50, if I remember correctly.
13 years motor trade, 16 years motor industry. 16 years Driving Instructor & 9 years Fleet Trainer
Panda Alessi (2015 Skoda Fabia)
portland_bill is offline Reply With Quote Quote
(T) 1.4 Tjet Clutch with Slave Cylinder or Concentric Slave Cylinder? Eridanny Bravo 9 22-12-2013 22:25
(T) Grande punto master clutch cylinder/slave cylinder Ramrodd Grande Punto 0 31-07-2013 17:43
(G) Clutch Slave cylinder Fretterz Punto (Mk2/2b) 1 05-02-2013 14:39
(T) 1.2 clutch slave cylinder simmyoto Stilo 9 06-12-2012 14:45
(T) Clutch slave cylinder Kendz Bravo / Brava 13 04-02-2005 13:43
