Yes.. most likely. Would I be able to replace this myself? I found the replacement part on eBay for about £55 .. but not sure about the access there..
I would then flush the cooling system and see if it works?
This is a great find, definitely going to try it. Only thing is - how do I know if the valve is closed? any other way than taking everything apart to look at it?
Just be aware that it's illegal to delete / blank the EGR valve on a vehicle used on the road and an undeclared modification can invalidate your insurance. That makes a "catch 22" as you can't declare a modification that makes the car illegal. The same applies to CAT and DPF deletion. It;s easy to recommend these modifications if you are not the one who might get a ticket. I know detection is unlikely, although the MOT introduced a check last year, but that doesn't help if you are the one who is caught. most, if not all, of the specialists selling EGR or DPF deletion modifions to ECUs will make you sign a dislamer.
Robert G8RPI.
