![]() | #1 | ||
Posts: 113 Thanks: 5 Trader Rating: 0 ![]() | Starter motor removal Whilst giving my 2004, 1.1, Panda, a service I have managed to drop a spark plug down the back of the engine block and it is now sat in the crevice formed between the starter motor solenoid, engine block and gearbox. I have tried various methods to try and fish it out but have had no luck. I have come to the decision that my only options is to remove the starter motor and then It will drop down. How hard is this likely to be?
![]() | #2 | ||
Posts: 1,109 Thanks: 75 Trader Rating: 0 ![]() | Re: Starter motor removal What harm can it do if you leave it there?
![]() | #3 | ||
Posts: 4,268 Thanks: 430 Trader Rating: 0 ![]() | Re: Starter motor removal Did you try a magnet on a stick? Or even better a bit of microbore copper pipe that you can bend into shape bur is stiff enough to keep control of it. Robert G8RPi.
![]() | #4 | ||
Posts: 113 Thanks: 5 Trader Rating: 0 ![]() | ![]()
![]() | #5 | ||
Posts: 113 Thanks: 5 Trader Rating: 0 ![]() | Re: Starter motor removal
![]() | #6 | ||
Posts: 1,109 Thanks: 75 Trader Rating: 0 ![]() | Re: Starter motor removal Yep - knowing it's there would freak me too. But a few potholes or sleeping policemen should shift it!
![]() | #7 |
Posts: 7,580 Thanks: 588 Trader Rating: 1 ![]() | Re: Starter motor removal Been there, done that. Best not to leave it there, when it moves it could short out the main battery cable to the starter, or get flung about by the rotating drive shaft. Jack it up, make sure it is supported well. Crawl underneath and reach up onto the top of the starter and remove it. Need the exhaust to be cold. This is difficult and fiddly, but best way to get at it if the magnet won't work. Removal of starter from below should not be too difficult. Disconnect battery first.
__________________ 13 years motor trade, 16 years motor industry. 16 years Driving Instructor & 9 years Fleet Trainer Panda Alessi (2015 Skoda Fabia) Last edited by portland_bill; 27-05-2015 at 23:43. |
![]() | Waldo99 | Punto (Mk2/2b) | 7 | 02-04-2014 17:41 |
![]() | andrew1620 | Ulysse | 1 | 24-11-2012 08:49 |
![]() | eamonnf | Punto (Mk2/2b) | 7 | 26-09-2012 13:43 |
![]() | volxstu | Stilo | 3 | 31-05-2011 18:35 |
![]() | christopher watson | Fiorino (Mk1 / Mk2) | 1 | 21-03-2006 18:58 |
