- Sep 14, 2009
- 19,492
- 3,294
Not true for a modern commonrail with pressures as high as 2500 bar and a pump lubricated by nothing but the diesel.
I agree on the MES though.
gr J
I'm not trying to suggest that incorrect fuels are a good idea, but a diesel engine will actually run on pretty much anything of reasonable viscosity. Resultant and potentially serious damage is a separate subject.
The OP's engine refuses to run at all suggesting something else is going on. The ECU codes need to be examined as a start point.
Liquids are not compressible so if they'll burn, the engine will run. Biodiesel for example is technically non flammable. Its flash point is well over 100C. But spray a fine mist and it burns very well indeed. Same with jet fuel. Both will work in a common rail diesel. Both are likely to cause long term damage though for different reasons.
Wikipedia
It (biodiesel) is slightly miscible with water, has a high boiling point and low vapor pressure. The flash point of biodiesel exceeds 130 °C (266 °F), significantly higher than that of petroleum diesel which may be as low as 52 °C (126 °F). Biodiesel has a density of ~0.88 g/cm³, higher than petrodiesel (~0.85 g/cm³).
