- May 10, 2010
- 2,669
- 797
A read of this might help.
http://www.obd-codes.com/p0202
As you've moved the suspect injector to another cylinder yet the fault still occurs with cylinder two, you can say with some certainty the injector is ok.
So with this presumption, you need to work backwards from that injector to the ECU.
Once you are sure the wiring and connectors are not responsible, then get the ECU checked.
