Technical Knocking noise at the rear
doug7126
Aldershot
Took the car in to my local garage today to try and find where this knocking is coming from?
Rear shocks changed for bilsten ones about 9k miles ago, bushes are a little worn but not to bad, bump stops look like they are in good condition. Any other ideas?
Mechanic wondered weather the spring cups should have some sort of rubber on them?
Having just read all the other posts on this I have just ordered some poly bushes from demo tweeks and will fit them and see if it makes any difference next will be the bump stops if that doesn't work, will try the 500 abarth versions as they are 11 quid each cheaper than the panda ones.
