...but only one crankshaft
Depends on the bore. If that's the same and only the stroke is bigger, it might fit.
I think the (in)famous captain from Portugal had a similar plan and we found out that they are not interchangable.
Missed the crank bit. I'd suspect it would but I'm sure the stroke is different. 1.4 would probably fit the 4x4 gearbox the superfire engines (16v) are based on the fire engines (8v) so bell housing mounts are the same etc
