Technical Front drivers electric window
Preston
Hi all,
My front drivers side electric window has decided to stop working.
When i press the button i can hear a relay click and nothing happens.
I have swapped the fuse with the passenger side and still nothing (passenger side works OK with both fuses)
Any one got any ideas before i pop the door card off and start replacing parts?
Any help or advice appreciated!
Hi there you are not on your own, that's exactly the same problem that I have with my 1.1 Active see topic below yours at 'New Panda problems to sort out' from me, I shallbe attacking it tomorrow weather permitting with the aid a Haynes manual and a good electrical engineer at the other end of the phone.
So here's hoping
Regards
Derek
Great stuff, thanks pandaforpops and portland_bill. (y)
I did have a slight breakthrough this morning though, after going up 10 stories of the works car par the window now seems to work OK again. Is it possible that its just a lose connection in the door?
Excellent news, better than mine, my quest goes on, unfortunately flexing the harness on mine did not help, but thanks again to portland_bill
regards
Derek
