Hi all - me again
You may remember I posted a while about having water trapped in my car and you all very kindly advised me on how to find my scuttle board drains, which I am now a pro at locating and check them monthly and rinse them through to stop any grit from building up. However, it turned out the problem was actually trapped water in the passengeer car door and I needed a new seal, which has been fixed. However, over the last week I have noticed the same thing occuring. Whenever I turn round a corner I can sometimes hear water; which sounds like it is coming from behind the dashboard. I have already done the following:
Checked engine coolant level when engine was cold - this is at maximum.
Checked scuttle board drains - clear and dry
I have to say that while the passenger footwell is maybe slightly damp, nothing that is alarming and could well be due to the residue from the leak from the car door. I did have the air con running quite a bit following this to try and dry the moisture out of the air, so I was thinking that maybe water is trapped in my air con?
I just wondered, as everyone was so helpful before, if anyone could provide me with an idiots guide of things to check. It could well be that there is still water trapped in the car door but I dont know how to check this and how I could clear them. Also,is there anywhere else water could potentially be trapped, and if so how do I check and how do I clear.
Thanking you all in advance.
