General ECU problems Fiat Panda
That sounds like an angry reply. Did you mean it that way?
There have been many threads in the past, mainly Punto 2/2A, with loose pins at the engine ECU. These have given symptoms similar to the ones experienced above. I seem to remember an occasional Panda with similar issues.
I agree that these pins are unlikely to become loose unless disturbed, but with an older vehicle it may have succumbed to clumsy handling.
Agreed.
And of course the mk2 punto highlighted then cost effectiveness of good spark plugs..
Giving the coil packs.. and in turn the ECU contacts an easier time.
I hasten to add ..
my coil pack changd was an error..
Trying to sort a 'non.start' issue that was actually a mechanical timing issue :(
