Thread Tools
Old 19-11-2013   #1
fiat panda ABS failure
i have a 2005 panda which has had the abs light come on also abs failure
lights up on the dash
had it checked at a garage which said o/s front senser was at fault
i have now put a new senser on the car but still have the same fault
the car reads no fault code found when hooked up to 2 different code readers all lights up when key is turned then goes off as normal
then within a couple of seconds abs lights and failure lights up
2000peanut is offline Reply With Quote Quote
Old 19-11-2013   #2
jon1612 has donated!
Re: fiat panda ABS failure
did you use right reader, as engine code reader will not show fault, you need adapter lead to connect to abs ecu, if lights on you should be able to get fault code from it
jon1612 is offline Reply With Quote Quote
Old 20-11-2013   #3
1st i used a ob11 reader then i took it to a local garage who pluged it into a proper code reader nothing no codes found but 35 lighter
they said i could book it in with them and they would check it over at 48 hour but thougt i would try on here first
Old 20-11-2013   #4
Speed Reader of the Year!
Most Easterly Pandas's Avatar
Trader Rating: 2
Most Easterly Pandas has donated!
Was it under the Panda ABS ECU recall? And if so has the work been completed
Most Easterly Panda's - Panda'ing in East Anglia
Stockest of mk2 Panda Parts, PM for any parts requests
1993 Classic Panda Selecta, 1989 Panda 750L,
2015 Kia Soul EV, 2009 Panda Eleganza & 2005 Panda Climbing 4x4 (LPG)
Most Easterly Pandas is offline Reply With Quote Quote
Old 16-06-2018   #5
mine had recall but they replaced parts not the "module" as described in recall, Fiat refusing to sort.
bearpanda is offline Reply With Quote Quote
Old 16-06-2018   #6
How recently was the ECU recall work done? If it was last week dont take no for an answer. Obviously, if it was longer you are on your own.
This with the correct leads should find the fault codes
http://www.multiecuscan.net
When an ABS sensor fails the code will be along the lines of "sensor fault"
When the ABS magnets fail it will say "no ABS signal"
You might need a new wheel bearing/hub.
DaveMcT is offline Reply With Quote Quote
Old 17-06-2018   #7
Trader Rating: 1
portland_bill has donated!
Quote Originally Posted by 2000peanut View Post
For Fiat ABS you need a Fiat specific reader. Some garages will subscribe to diagnostic services, others don't, so they may not have the ability to read the ABS module. Needs MultiECUscan (MES) (Search on here for explanation) or Fiat dealer. (Last resort)
Has any other work been done just before the failure? Wheel bearing, or any other work on a hub?
Has anyone cleaned under the bonnet, or has the car been through any deep water or puddles to cause any water issues with underbonnet connections?
Update your profile to show your location. There may be someone nearby with MES who can read the codes for you.
13 years motor trade, 16 years motor industry. 14 years Driving Instructor & 7 years Fleet Trainer
Panda Alessi
portland_bill is offline Reply With Quote Quote
Thread Tools
(G) ABS failure EBD Failure Switch off engine Call Garage Handbrake lamp on SillyBilly Multipla 0 15-03-2008 22:16
(T) ABS Failure. Migaard Marea 0 19-01-2006 12:35
(T) ABS failure krca Bravo / Brava 5 03-11-2004 00:15
