2000peanut
- Nov 19, 2013
- 4
- 2
i have a 2005 panda which has had the abs light come on also abs failure
lights up on the dash
had it checked at a garage which said o/s front senser was at fault
i have now put a new senser on the car but still have the same fault
the car reads no fault code found when hooked up to 2 different code readers all lights up when key is turned then goes off as normal
then within a couple of seconds abs lights and failure lights up
