Technical Problem with ABS and electrical system
RikkesPanda
Hi there,
I have a Panda 1,2 Dynamic from 2009 - bought used this summer.
I have had a few incidents I hope you can help with before I take it to the shop.
1. I was in a line of cars, holding still and getting ready to turn right when I had to turn suddenly I could not move the stearing wheel and the light in the ABS was on. It was stuck. So I turned off the engine and when I turned on again the problem was gone.
2. A week later I was again in a line getting ready to turn when suddenly I could not press down the break pedal. I turned the engine off and when it came back on, everything worked again.
3. Now I have just lost the backlight in the dashboard in the area where you turn the heat and air on and off.
Any ideas as to what might be the issue?
Thank you guys
