randysbits
Following a recent major service i carried out on our car, (timing belt & aux, water pump etc), a pig of a job and i will document this in time, i decided to have a nose at the intake system and delve a bit deeper into the flow. First off, i felt the initial 90 degree bend that enters the air box from the from panel was a restriction, or rather, an interrupted path for air to flow efficiently, the offending suspect being the odd loop chamber which must be tuned to reduce induction noise. A simple solution to this occurred to me that i had, various pieces of material at my disposal and one of them being a sheet of aluminium from an old appliance. Not wanting to spend too long faffing around with this, i cut a piece from the sheet big enough to cover the loop chamber, forming it to a nice neat enough blanking plate, then with some of that carpet and vinyl adhesive (aerosol based), applied a little to the inside of the pipe and little again to the aluminium piece, once tacky, (anyone having used this stuff before knows, this don't take very long at all), slid the aluminium into position and also crushed the plate into the grooves at the start and end of the pipe inside. The result was very pleasing considering i wanted a quick fix solution, & not least as this has in effect cost me nothing & completed within 5 minutes
Next up, i thought while i had the air box removed i would delve into the air box & check the K&N panel filter that had been fitted about a couple of years ago, all good, surprisingly clean so i moved further on...
The trumpet shaped piece that is removable via two self tapping screws on the right hand side of the box has, a small but significant oval hole that leads to a massive air chamber to the rear of the box that effectively does nothing other than again, reduce induction noise by way of a measured volume. I removed this trumpet, cut another piece from the aluminium sheet to a decent oversized dimension, offered it up, trial fitted the trumpet, job was a good'un so refitted the screws, another void blanked off and even quicker than the first one that i did !
Not being happy with the poor fit of the induction pipes that enter and exit the box, i decided to seal these with a generous bead of silicone, waited for it to cure completely then, refit the entire air box in one piece. The result...? a nice improvement in air flow, noticeable increase in torque, slight increase in acceleration maybe (albeit a placebo effect) due to new found induction noise that essentially is for FREE !! This for me, begs the question why you you would want to throw any real money in this area because, as cheap mods go, the fundamentals are already there, its just a question of how you address it.
Thought i would share this with you all as, its something i wish i had done when i fitted the filter all that while ago, its quick, simple, effective, and free if you have the right stuff lying around but remember, this is just a suggestion as there is far more room for improvement as regards air flow, i may even get a tapered plate moulded up if i get really bored one day to, mask all those heat shrink type fins inside the box that are crude but, just part of the manufacturing process and aid some rigidity, just a thought for the future though...:idea:
