Technical Windscreen washer pump...
DaveMong
Hello, my dad needs some help with his windscreen washer pump. When he pulls the stork, nothing happens at all, no water, no pump noise either. He wants to know the location of the fuse for the pump. Also the location of the actual pump so he can check it out anyway.
Thanks in advance.
On page 147 of the handbook, it shows the location of the washer fuse (F53)
http://www.wanderlustonline.com/New_Panda_Handbook_07-07.pdf
It's in the fusebox by the drivers knee.
You have to see the diagram, it's too difficult to explain the location.
As for the pump itself, I have no idea, but no noise probably means no power.
Just make sure to put the right fuse in, so if it is a pump motor problem, you don't draw too much current.
