I've looked everywhere to see how to get the front bumper off my panda 55 plate 1.1 active as i want to do some minor body work on it. can anyone help with a detailed/ step by step guide on how to do this at home?
cheers
Sav
I found some good instructions on this forum when I needed to get mine off but from memory.
Open the bonnet and remove the plastic grill (mine is a 59 plate with the revised grill though) which reveals I think four bolts you need to remove.
Under the front bumper (lie on the floor) I think there's four or five bolts. Remove these.
Then under the wheel arche I think there's another one each side.
Undo the under wing protector (front wings) and get a torch. Look under the wheel arch liner to the very front of the wing. On mine there's a bolt I had to remove (one each side).
After that it just drops off
It wasn't difficult so you may have found all this out by now.
ive managed to get all the screws and bolts out, but i cant seem to free up both of the wings? any advice? ive taken off all the screws for the wing protectors and its moving around. do I need to remove this panel?
