I'm renewing the rubber bush on the front suspension lower wishbone on my 2004 Panda, so I need to remove the wishbone arm. The two inner mounting bolts came off easily enough but I'm struggling to split the lower ball joint.
I've removed the nut from the pinch bolt passing through the casting but I can't remove the bolt. Should this just tap out or is it threaded into the casting?
