I was wondering if anyone else has experienced this. I had the Panda parked up for a couple of weeks and when I went to start it i found the motor wouldn't turn. I assumed it was the battery so I charged it overnight but had exactly the same problem. I kept trying to start it still assuming the battery was flat until I discovered white smoke appearing from under the bonnet. It was clearly from something electrical and I suspect the starter motor although it's not easy to see it from the top. I am assuming either is is jammed in some way or something is wrong with it like the brushes are worn. Does anyone have any ideas what could be wrong?
