Greetings!
I have a Panda Multijet 2004 (October, so before ESP units were installed).
The problem that I have with the car since I bought it (last year) is with the brakes.
The car sometimes starts braking slightly.
I already changed all braking accessories.
Brake pads, discs, tubes, brake fluid. Even the brake lights switch.
After changing all that I notice that if I don't connect the brake light switch the car works perfectly.
So must be something related to the ABS. The problem is electronic for sure.
The car does not have ESP.
But it does have 4 wires for braking and a 4 pin plug (usually only used for 'Dynamic control' or in other words ESP).
The Fiat dealer has no idea what's the problem.
They say they never saw it before.
I bet they want to change all and then charge me big time.
What can I do?
Any help would be great!
ps. I'm starting to think next time I will buy something Korean.
Someone with the same problem:
For no apparent reason my Grande Punto (1.9 Multijet) applies the brakes and stops during journeys. If I turn off the engine and wait 5 or 10 min you can then drive again. Have changed the brake hoses, the Calipers and had it checked on a number of occasions by Fiat and Halfords. No one can find the problem. It is quite an issue as they come on very quickly! Anyone had the problem or can suggest a solution?
http://www.honestjohn.co.uk/forum/post/index.htm?t=94411#m1040137
What can I do?
