thespaceman
- Mar 2, 2009
- 10
- 4
Ignition switch dead - no power
Hi all,
my 2005 Multijet sporting has developed a fault where the ignition switch does not work anymore. This happened suddenly so I suspect it may be a fuse or relay.
The lights and central locking work ok and the dashboard digital display works when opening the door and I'm getting over 12.3v at the battery.
When I turn the ignition switch however (have tried both keys) nothing happens and the dashboard lights do not come on and the starter does not operate etc.
I've check some of the 20A fuses in the fuse box under the dash and in the engine compartment. I've also swapped some of the relays around where possible (when there is more than one of same type). but still no joy.
I've taken the cowl off underneat the steering column and removed the multiplug from the ignition switch (the one with 3 wires) . I tested each for a voltage but all 3 are dead.
Any ideas what may be causing this? I think it is a fuse but not sure which one would power the ignition switch.
TIA
Hi all,
TIA
