Old 16-05-2012   #1
Exclamation Supposed Injection System Failure.
Hi there,
I have a 56 reg Panda, and it has just been to Available Car for a cam belt exchange.
On the way home down the M1, I noticed an amber light flashing on the dashboard. According to my handbook, it is an injection system failure. Now, it was running perfectly fine before, so I was wondering if it could have anything to do with the new cam belt. Interestingly, the light only started flashing if I went over 65mph, and if I continued at that speed, it eventually turned off, however, if I accelerated, it started flashing again. As far as I could tell, the car sounded the same and there was no noticeable loss of power.
Has anybody experienced this?
MissCEM is offline Reply With Quote Quote
Old 16-05-2012   #2
Romania
Re: Supposed Injection System Failure.
Welcome to the forum, and good on you for checking the user manual first!
I think you mean the "check engine" light witch can be set off by a lot of things, not just what they say in the handbook. I got that light from a error from the acceleration pedal once..
Sadly I can't give you any other info on this, but it might not be the injectors!
dandt87 is offline Reply With Quote Quote
Old 16-05-2012   #3
Thanks for the reply!
If I continue having problems tomorrow, I will get my Mum's friend to have a look. I'm just hoping it is a loose connection or something. Available Car had to strip my car completely to fit the cam belt, so it would make sense if they didn't connect a cable properly.
If there are any more problems, I will post on here!
Old 16-05-2012   #4
Romania
When you get it fixed, please let us know what it was, so that other know where to look if they have a similar problem.
best of luck!
Old 20-05-2012   #5
You need to get the fault codes read by a fiat dealer or suitably equipped garage. How come you took the car to Available Car to get the cambelt changed? I thought they were a car supermarket? Did you buy the car from them recently?
Likes james2609 liked this post
lamlash is offline Reply With Quote Quote
Old 01-06-2012   #6
They were supposed to have installed a new one before I picked the car up, but they didn't, so we set a date and they did it for me. Within 30 days of buying, they will carry out any works necessary if anything goes wrong.
(T) Injection System Failure vincenze Multipla 1 07-06-2009 18:06
(T) Injection system failure! Charlotte1988 Punto (Mk2/2b) 5 13-01-2009 21:15
(T) Injection system failure??? supermcc_afc Punto (Mk2/2b) 8 03-10-2005 20:07
(T) Injection System Failure??? multipla-aire Multipla 8 06-08-2005 20:15
(T) injection system failure? Bravo_wales Bravo / Brava 8 22-07-2004 05:59
