All,
Over the last few days i hvae carried out a major service on the car, before i started i was listeneing to the engine and whilist the bonnet was up and on tick over you can hear a rythmin "click" comming from the left hand side of the engine, as you face the front of the car. The "click" is like the sound of something catching as a belt or bearing rotates.
As you rev the engine the noise cannot be heard above he sound of the revs so uits difficut to determine if it disapperas or increases in line with the revs.
The car has done 30000miles and is an 07 plate.
My thoughts were:-
Could it really warrant a belt and tensioner change at this low milage, and could/would the sound like this be eminating from the timing belt ?
Loathed the start stripping down and replacing to find out its not that ?
Any other ideas, anyone else experianced this, i appreciate a sound is didfficult to describe but all ideas or thoughts are welcome.
Would idealy start with changing and ruling out the simpler items first before moving onto big expense and time.
Am i right in the fact that this engine is a non interferance unit so will not be damaged in any way if the timing belt or pulley tensioner fails ?
Thanks in advance.
My thoughts were:-
- Timing belt
- Timing belt tensioner
- Dry bearing or signs of wear in a bearing
- Water pump (perhaps)
- Altenator belt
Thanks in advance.
