My Dynamic is coming up to a year old and has 5,300 miles on the clock. It does seem to be a lot more responsive and smoother. I still get the occasional "judder" but it seems to be when just starting off, ie, when revs are low and the clutch is just catching. Maybe I need to have higher revs (above 2000) before engaging the clutch? I`ll be trying that over the next month or so and see if it makes a difference.
I love the car though, it`s better than the Seicento - holds the road just as well ut more comfortably
You should not need any throttle when engaging the clutch, if you do it slowly enough. You should be able to put it in 1st gear, and just ease the clutch up, no drama. If you are needing >2000RPM to move off, your car has a fault IMO. (of course, this could just be you still getting use to the biting point, and the clutch bedding in, thus, it may go away in time)
