- Jan 3, 2012
- 22
- 7
Hi Panda gurus,
I've got a 2005 Panda 4x4 1.2 and love it to bits, unfortunately it has recently developed a small leak on the petrol tank where the 'filler arm' tubey thing meets the tank itself. I've been advised against a plastic weld repair on these types of tank so I now need to replace the whole thing.
The local Fiat garage here wants to charge R8000 (about £750) to replace it, however a local workshop has offered to build me a new one from scratch, in steel for quite a bit less.
I do a fair bit of off-road here in South Africa and steel fuel tanks with extended range are a popular upgrade to Landys etc. because they are (allegedly) more robust and less likely to break than the plastic ones. They rubberise them, pressure test etc. etc. and claim that they are better than the originals.
So I was wondering if anyone has any experience with replacing the petrol tank on a Panda 4x4 with a custom made one? Is this a really stupid idea and I must just bite the bullet and buy a proper Fiat one or could it work? I was also considering the idea of modding the tank to have an increased capacity for longer distance? Perhaps even building a second tank into the spare wheel well or inside of the boot. Again - any advice appreciated.
I suspect a proper Fiat tank and a jerry can is the most appropriate solution for my woes, but a Panda 4x4 with a range of over 1000kms is too tempting not to ask the question!
Thanks in advance, great forum :worship:
