M Mcpanda New member Joined Feb 1, 2011 Messages 7 Points 3 Feb 5, 2011 #1 Hi does anyone know if the drain plug for a 1.1 54plate panda is a 12mm key? I need to buy one so don't want to get the wrong size.
Most Easterly Pandas Speed Reader of the Year! Parked in the garage Written a guide Joined Aug 15, 2007 Messages 44,236 Points 7,382 Location Norwich, Norfolk Feb 5, 2011 #2 Mcpanda said: Hi does anyone know if the drain plug for a 1.1 54plate panda is a 12mm key? I need to buy one so don't want to get the wrong size. Click to expand... Its either 10mm or 12mm from memory. Depending upon the type of key you get it'll be a double ended 10+12mm key so you should be ok.
OP OP M Mcpanda New member Joined Feb 1, 2011 Messages 7 Points 3 Feb 5, 2011 #3 Its Definitely 12mm the local auto place let me check it before I left, thanks for the help.
