Hi All,
Just wondering if anyone else has experienced their gear changes becoming stiff? I've got a 2005 Panda Active and all was fine until just before Christmas, when the clutch went very heavy and slow when the car was cold. Now the clutch seems ok but now the gear changes are heavy/stiff. The gear stick used to spring quite lightly between the gears.
My garage have suggested that it is a fault with the clutch control cable, with a fitted replacement cost of £300.
does the diagnosis sound right? Has anyone else had the same problem?
(words chosen carefully to avoid 'oooh matron' moments!)
