andergrass
- Jan 15, 2011
- 1
- 1
Hi i have a panda 1.2 active 2004 it uses too much fuel eg 200mile per tank full runs fine no stalling have no fuel leaks any ideas what is the problem would be of great help thank.
The Panda has a 30 litre tank so that is around 30mpg which seems low. What sort of driving are you doing? When was it last serviced? New plugs, oil change and a new filters can do wonders for MPG.
I assume you have checked the tyre preasures (every little thing adds up)
35 litre tank, the odd thing i find is that i can get more than 35 litres in it?
Modern car fuel systems are designed to work with an air space & it is possible to 'drip-feed' perhaps another 5-7 litres of fuel into that air space if you continue to trickle fuel after the pump first cuts off. On my Panda & 500 (they share an identical fuel tank) I get 32-33 litres to first cut-off with about 25 miles range to go, which corresponds well to the manufacturers stated capacity of 35 litres.
Some folks report filling the design air space with another 5-7 litres of fuel to extend range & get accurate comparative fuel consumption readings. The manufacturer specifically advises against this in the owners handbook and although some have done this regularly without obvious issues the low & high pressure relief valves & evaporation control canister are not designed to be flooded with fuel & there is a risk that overfuelling could permanently damage the fuel system.
Given the warning in the owners documentation, I would not expect any such damage to be covered by warranty.
Sorry, where have you read this?
You cannot over fuel your fuel tank. Wouldn't pass and regulatons if you could and I've not read that warning ever in the handbook for any car we own (and I've read them all front to back ).
There is a warning about overfuelling in the owners handbook for both the Panda & the 500. The relevant sections are attached.
