Right, quite happy with my parts collection. Picking up some replacement seats on Sunday and have got some 16" alloys that I am having second thoughts about, but time will tell. Seen some good Panda bargains come and go, but none that really fit the low-cost ideals.
I have found a rear suspension setup from a 4x4 in a scrappy. I got the quote for the subframe, two arms and anti-roll bar back today for £450 delivered. That is naked without any other parts, including hubs, stub axles etc. Should I or shouldn't I? I think it is expensive for naked parts that I think few will want, but compared to the £1500 FIAT want, maybe it's OK? From an 80k miles car.
It is potentially a high performance suspension solution when used with Abarth dampers, springs and bump stops, but carries a reasonable risk of being an underwhelming upgrade that causes unknown issues. Is there any precedent for this upgrade out there? What do you guys who know about car handling think?
I am pretty sure all the 2WD parts will just fit on based on my lengthy research. Only things I don't know is:
1) Does the 2WD Panda have theaded holes in the floorpan for the rear aprt of the 4WD subframe to attach to?
2) Will a 2WD stub axle fit on the arms or do I have to get 4x4 ones from scrappy at about £100 more at a guess?
If anyone has photos of these things it would be great to see. Can anyone with a 2WD Panda have a look for those rear mounting holes/blanks please?
Diagram attached from
ePer of the parts to help.
