2005 Panda Dynamic
On some journeys the lights mysteriously go off then on, then off and on several times and then correct themselves. This is not just outside the car, all centre console and dash board lights follow the same routine simultaneously. The only light which stays on is on the radio. Sometimes I can hear a slight clicking as the lights play up. Every so often when the lights correct themselves some of theh centre console lights remain unlit. All these things happen when driving on even and uneven roads, with or without using the high/low beam and indicator stalk.
