Hello guys I hope you didnt mind me troubling you with another couple of questions.
I have noticed recently that im getting a white residue on the bodykit on my 100HP. Even if the car is cleaned its still white and wont wipe off. As mentioned in a previous post I have had my car polished recently. The guy who did it said he would also cover the unpainted kit and that it would be fine. I trust him as he is a family friend and I know he does the same on Fiats he owns. He used Diamondbrite and its a clear polish not a white substance like most of the others. So is that what the problem is, if so is it permantley damaged or is there a way to fix it? I am not jumping to that conclusion yet as areas that I know were not polished (like the wiper arm plastic panel) also have the white residue on them. Its a relatively easy fix to remove I just use Armourall wipes and boy do they work. It brings all the plastics back to life and they look better than new. However its fairly labour intensive and only lasts a couple of weeks. Can anybody recommend a better product that will last longer before retreatment? I am sure most 100HP owners use some form of plastic polish on the body kit.
Now onto my second question. After having the car washed I noticed that the door indicator on the dash was lit and it said hatch open. So I pulled over and opened the hatch and shut it again and made sure it was shut properly. Despite this after setting off the door light was still lit and it was still telling me it was open. I decided to just drive home as it was clearly shut tight. I noticed though that the door light and the message started flickering on and off before finally going off altogether. Could this just be caused by water getting on the lock mechanism or is this a common fault? I havent driven the car since so cant report if its doing it again.
