| Thread Tools |
![]() | #1 |
Posts: 968 Thanks: 49 Trader Rating: 0 ![]() | New Front Discs and Pads At 73,550 miles the original front discs have been replaced and a second set of pads fitted. Having looked around, I ended up buying Pagid discs and pads from www.eurocarparts.com for £100 inc. vat and delivery. Original discs: New discs: ![]() |
![]() | #2 | ||
Posts: 23,720 Thanks: 845 Trader Rating: 0 ![]() | Re: New Front Discs and Pads Obviously don't know how much you paid for the discs but Brembo discs are very reasonably priced if you want some more in the future ![]()
![]() | #3 |
Posts: 968 Thanks: 49 Trader Rating: 0 ![]() | Re: New Front Discs and Pads Thanks for that - I still have the link bookmarked from when you suggested them before ![]() Brembo were the same price but couldn't supply the pads - so it was easier to place a single order. |
![]() | #4 | ||
Posts: 1,557 Thanks: 66 Trader Rating: 0 ![]() | Re: New Front Discs and Pads OK, answer this; 1. How did you get front discs to last 73,550 miles, don't your pupils use the brakes? The discs on my Panda 4x4 Climbing were worn below the wear limit at 24,000 miles! 2. How come there's so little rust on those old discs? Has it stopped raining there in Birmingham since I lived there in the late 70's, or can the local authority no longer afford to grit the roads?
![]() | #5 |
Posts: 3,767 Thanks: 71 Trader Rating: 0 ![]() | Re: New Front Discs and Pads OK, answer this; 1. How did you get front discs to last 73,550 miles, don't your pupils use the brakes? The discs on my Panda 4x4 Climbing were worn below the wear limit at 24,000 miles! 2. How come there's so little rust on those old discs? Has it stopped raining there in Birmingham since I lived there in the late 70's, or can the local authority no longer afford to grit the roads? I expect most of the learners are braking pretty gently rather than charging up to roundabouts and slamming the brakes on as an example.
__________________ 2008 Red Panda 100hp - Sold May 2011 |
![]() | #6 | ||
Posts: 9 Thanks: 0 Trader Rating: 0 ![]() | Re: New Front Discs and Pads I must admit I'm tempted to replace my discs and pads - would the replacement discs such as Brembo be of better quality? The hubs are very rusty. Peter
![]() | #7 |
Posts: 3,767 Thanks: 71 Trader Rating: 0 ![]() | Re: New Front Discs and Pads Rusty hubs really do not matter.
![]() | #8 |
Posts: 968 Thanks: 49 Trader Rating: 0 ![]() | Re: New Front Discs and Pads OK, answer this; 1. How did you get front discs to last 73,550 miles, don't your pupils use the brakes? The discs on my Panda 4x4 Climbing were worn below the wear limit at 24,000 miles! 2. How come there's so little rust on those old discs? Has it stopped raining there in Birmingham since I lived there in the late 70's, or can the local authority no longer afford to grit the roads? ![]() I think that Lauren has answered your questions already. Students do not brake hard - good forward planning avoids them having to do so! ![]() ......and anyway, with an underpowered car, braking is the last thing you want to do! ![]() ![]() As for the disc bell not being rusty, I think that it's that way because the car is in constant use. The best discs and pads I ever fitted to my ITR track car were Pagid [although they were £130 for each], so I think that the quality is there. |
![]() | #9 |
Posts: 294 Thanks: 7 Trader Rating: 0 ![]() | Re: New Front Discs and Pads Can you get different calipers as well as I think a set of brembo front calipers would look pretty nice. Also a bit off topic but I like your abarth badges under your indicators. ![]()
__________________ Fiat Panda 100HP (07) Honda RVF400 NC35 (94) |
![]() | #10 |
![]() | #11 | ||
Posts: 23,720 Thanks: 845 Trader Rating: 0 ![]() | Re: New Front Discs and Pads The brembo GT set for the 500 would probably fit but like Lauren says, what's the point? Plus you probably need at least 16" or 17" wheels.
![]() | #12 | ||
Posts: 2,592 Thanks: 113 Trader Rating: 0 ![]() | Re: New Front Discs and Pads Sound advice given already. There are one or two things to take in account when buying pads & discs. Do you have ABS & you could have the best set up but let down by your tyres. Are you a fast driver & use your brakes often & hard. Obviously in your case standard pads & discs will be fine. Inspecting the system & changing the brake fluid is always a wise move also.
![]() | #13 |
Posts: 968 Thanks: 49 Trader Rating: 0 ![]() | Re: New Front Discs and Pads |
![]() | #14 |
Posts: 294 Thanks: 7 Trader Rating: 0 ![]() | Re: New Front Discs and Pads Thanks for that - I don't know why Fiat chose to place them on the rear three-quarter panel on the 500 Abarth? ![]()
![]() | #15 | ||
Posts: 596 Thanks: 11 Trader Rating: 0 ![]() | Re: New Front Discs and Pads What's the least amount of miles that anyone's done on the original pads? I've got a very good deal of discs and pads, so just need to justify the cost!
Thread Tools | |
![]() | jpholroyd | Stilo | 5 | 13-08-2008 14:02 |
![]() | lgraham | Stilo | 18 | 01-07-2008 15:22 |
![]() | jonny cinq | Stilo | 4 | 28-06-2008 18:29 |
![]() | Italian Coke Can | Cinquecento / Seicento | 17 | 11-06-2007 16:32 |
![]() | r_wiggy | Cinquecento / Seicento | 6 | 16-05-2005 22:44 |
