smallpauliscool
hi there all,
Does anyone know if the 500 arbath exhaust fit panda 100hp.
many thanks paul
many thanks paul
i've had a brief look into this, the way the exhaust is routed is the same, where it comes over the rear axle etc and theres obviously space under the floor for it. It would require some new mounts to be welded to the boot floor but the biggest problem is where the pipes exit, i never got as far as getting the width between the two tailpipes, this would be key to see where they'd come out, i have a feeling it will be far too wide though, i do have an idea to get round that. if i see a cheap one on ebay i'll get it and have a little measure up.
Trouble is, Abarth is turbo, Panda is not so the exhaust is unlikely to be optimal for the Panda.
Surely it would be cheaper to just have a custom s/s exhaust built by somebody like Cobra Sports etc.
Well exactly, plus the wheelbarrow look is a tad excessive for a 1.4 litre engine. I mean twin pipes? Really?
I had huge quad pipes on a car I once owned so I cant talk but yes a single pipe is best.
I have a question about the exhaust. If you remove the centre box on the 100HP (the one after the CAT) and just have a straight through pipe (as in the one from Gazella racing) will it fail its MOT?
If it's mild steel it's an absolute waste of time putting it on. If you replace your exhaust it has to be stainless steel.
Hmm wouldnt go that far, i'd happily buy a mild steel or aluminised steel exhaust, any decent exhaust should last 5 years or so, alot longer than most of us are likely to have our cars, considering stainless is usually a fair bit more expensive i don't see it's always worth it, unless your keeping the car for a long time.
