im Axle Specialists
Old 25-05-2010   #1
overheating issue in traffic
hello all,
i own a 54 plate panda dynamic just coming up to 29k on the clock, recently i have been experiencing overheating in traffic the needle gets to the last white division before the orange area, so its nearly vertical if that makes sense. what temperature does the fan kick in?( or area on the temp gauge to listen out for it)
also what would cause the overheating (apart from ambient air temp obviously) as this exhibits the same thing even before the hot weather.
current fix is to sit with the windows down and fans on full to cool engine down, which isnt fun.
are the rad caps prone to going thus loosing pressure?
any suggestions greatly anticipated
Currently owned:
54 plate "New Shape" Multipla & Panda
"Better a bad day on the Track than a good day at the Office"
petebarchetta is offline Reply With Quote Quote
Old 25-05-2010   #2
Re: overheating issue in traffic
Sounds as though the cooling fan is not operating.
I would suggest you check all the circuitry, this includes the temperature sensor, fuse, fan motor, wiring, any relays etc.
Sorry but I can't give you a flow diagram as to exactly how to perform these checks, maybe someone with more experience will come along.
doctorchris is offline Reply With Quote Quote
Old 25-05-2010   #3
Have you changed the coolant recently? if so, it could be an air lock. If not possibly a blown fuse.
I'd do the checks the Doc said first tho
harry monk is offline Reply With Quote Quote
Old 26-05-2010   #4
Sorry to hear about this, the same happened with my Panda, and it needed a new radiator fan. Dealer fitted = c.130 as I recall, but an easy DIY fix if you feel that's the problem (I am assuming the fan isn't kicking in as the engine temp rises).
Given that summer is more or less here (or have we had it already now ) it would be worth doing sooner rather than later I'd say.
Good luck
james_f is offline Reply With Quote Quote
Old 26-05-2010   #5
The fan should kick in just past the half way point on the thermometer. Certainly sounds like yours is not doing this.
Check fluid levels (as suggested above) -- if you have the reservoir on the side of the radiator itself, it can be tricky to do this - but one way to make it easier was outlined here: https://www.fiatforum.com/panda/1761...ml#post2319655. If the tank is mounted high up on the driver's side wing, then you can easily see the level through the side of the tank.
If coolant level is OK, something else to check is that there's not air locked in the system (although trapped air usually ends up causing probs with the heater, rather than the rad) -- if your heater's not blowing hot air, then see here: https://www.fiatforum.com/panda/2292...ml#post2426485 [edit: re-read your post, and clearly your heater is working]
If these are OK, then four options in order of increasing cost:
  • temperature sensor on the radiator (by the way, check the wires to that are properly plugged in and haven't broken where they meet the plug) [Note- unlike older cars, this is an electronic sender, not a thermostatically-operated switch so harder to test]
  • the thermostat on the engine plumbing (to test this, start the car cold and feel the radiator hose by the battery. This should be cool. As the car runs and warms up, the thermostat will operate after 3-4 mins with the engine idling, and this hose should then become hot to touch.)
  • the fan on the radiator itself. Could test this by removing the plug and applying 12v but mind your fingers! Maybe best to remove from the car before trying this.
  • or the water pump in the engine block, powered by the timing belt and pretty hard to check without taking things to pieces.
Pete
2018 Panda 4x4 MJ :: North Herts :: Remember, if you find a post helpful, press the smiley face 'thanks' button below
Herts Hillhopper is offline Reply With Quote Quote
Old 27-05-2010   #6
Speed Reader of the Year!
Most Easterly Pandas's Avatar
Trader Rating: 2
Most Easterly Pandas has donated!
Cooling fan is CAN operated iirc.
Run a live diagnostics if you have the kit and check coolant temp is being recorded etc
Most Easterly Panda's - Panda'ing in East Anglia
Stockest of mk2 Panda Parts, PM for any parts requests
1993 Classic Panda Selecta, 1989 Panda 750L,
2015 Kia Soul EV, 2009 Qubo Dynamic Dualogic WAV & 2005 Panda Climbing 4x4 (LPG)
Most Easterly Pandas is offline Reply With Quote Quote
Old 27-05-2010   #7
Quote Originally Posted by petebarchetta View Post
hello all,
i own a 54 plate panda dynamic just coming up to 29k on the clock.....
No offence, but how come you're not in the classic forum then? Where's the mods when you actually need one?
greyridertoo is offline Reply With Quote Quote
Old 27-05-2010   #8
Twin Turbo powered :-)
udtrev's Avatar
udtrev has donated!
Bedeviled Plus Champion
Talking Re: overheating issue in traffic
Quote Originally Posted by greyridertoo View Post
Ahem, a 54 plate is not he classic panda, the OP has the correct section.
It's amazing how long the wee beastie has been around
For all Chrysler help got to http://www.chryslerforum.co.uk/
udtrev is offline Reply With Quote Quote
Old 27-05-2010   #9
Quote Originally Posted by udtrev View Post
Too early in the day for me to get the dates right (Doh!)
Old 27-05-2010   #10
Trader Rating: 2
Panda's didn't even exist in 1954
mk1 1980-1987
mk2 1987-2003
mk3 2003-present
Old 27-05-2010   #11
I didn't say that I thought it was a 1954 vehicle. I did misread the post, however.
Old 27-05-2010   #12
udtrev's Avatar
udtrev has donated!
Hey Jon
You got competiton for speed reading
Hmmmmmmmm thinking what I am thinking Jon ?
Old 27-05-2010   #13
Trader Rating: 2
What did you think it was then if you saw 54 and thoughts it was a classic panda
I'm confused
Old 28-05-2010   #14
I have no idea now what I thought at the time, other than thinking it was a classic and suggesting it was in the wrong forum. Why? As I said, I obviously misread; I tend to look in the forum early before heading out. Why do I need to justify my error to you?
Quote Originally Posted by LeanMeanRacing View Post
"........a small percentage have experienced an element of unreliability."
Old 28-05-2010   #15
Trader Rating: 2
You don't.
I was just curious.
(T) Back again ... This time going over the heating/overheating issue. TheBauer Cinquecento / Seicento 79 10-01-2009 00:27
(G) Overheating Issue kriss Bravo / Brava 6 08-10-2008 16:05
(T) Engine overheating when sat in traffic xxxShazxxx Multipla 2 10-08-2007 14:48
(T) 75 ELX Overheating issue Mole Punto (Mk1) 6 02-08-2007 14:38
(T) Overheating issue - fan not working Thatcpfcguy Punto (Mk2/2b) 5 18-09-2006 10:03
