Thread Tools
Old 10-04-2010   #1
Injection system failure light
Hi. I own a 06 multijet and have been suffering again with loss of power. Today i was driving up quite a steep hill, changed down a gear and the injection system failure light lit up. I pulled over turned off the ignition and then restarted the engine and no light appeared. Is this a serious problem? This is the first time this light has lit when driving.
Any advice will be greatly appreciated.
newby is offline Reply With Quote Quote
Old 12-04-2010   #2
Re: Injection system failure light
Quote Originally Posted by newby View Post
somewhere here there is a thread on loss of power to same model as yours,my fix was to remove both multi pin connectors on the ecu(the box on the right of your engine)you may have to cut 2 cable ties before you can lift the arms to remove plugs.once off spray with electrical spay you can buy from most car diy places.leave to dry then give it the wd40 treatment put back and all should be well,
bobbyg is offline Reply With Quote Quote
Old 12-04-2010   #3
Smile Re: Injection system failure light
Many thanks for the advice. Will give it a go
Thread Tools
(G) ducato injection system failure light on ray 100 Ducato 3 30-07-2008 19:54
(T) Injection System Failure light on Raistlinsmum Doblo 0 11-06-2008 18:17
(T) Injection System Failure Warning Light mally Punto (Mk2/2b) 15 03-06-2008 00:02
(T) injection system failure light has come on, advice please. fletcher11 Punto (Mk2/2b) 3 24-04-2008 21:25
(T) Injection system failure warning light Vignale Gamine Cinquecento / Seicento 12 23-06-2007 21:00
