General Panda 100hp - Abarth badges and wheel centres.
Depends what bits you put on it really. A badge alone isn't enough (obviously). However had you put a Cossie engine in it with associated running gear, then fair enough.
OK then, the OP needs to put some official Abarth bits on it...They do a Fuel Cap or Mats...Stick them on, job's a good 'un....
:D
:D
Does it work the other way around. What if you have a 4x4 panda and the 4x4 badge falls off. Do you then have to remove the 4x4 running gear. ;)
I could be wrong, but I have the feeling that one or two contributors to this thread are taking the pi** out of someone. Now, who could that be?
Ah so it depends what you got in your car before you put the badges on. You better rolling road your car and make sure it had 100HP. Else you need to remove your badge.
How many time in this thread have you said along the line, is up to you is your car? Surely once is enough ? Your point is made in the first page or so.
Ming
Ming
Its irrelevant what power my car produces as it's a genuine 100hp from the factory.
But meh, mission achieved, sparked some debate didn't it?
But how do you know it definitely has or had 100HP? Rolling road results are very inconsistent, you could get 10 readings from 10 different places all over the country and they'd all vary (if you did that though you could work out the average)
On the plus side, most of the members on the Abarth forum have been getting much higher readings for standard A500's, lowest was 139 HP highest was 161 HP! :rolleyes: Pinch of salt anyone?
It's irrelevant what power it produces. It's a genuine panda 100hp from the factory. When I say the model of the car I'm not referring to how much power it has or not. It just happens to be that the power output is in the car's name.
IF Abarth had involved themselves maybe we av all assisted in the product development of what said Panda may av looked like...ce la vie people. life is too short to worry about other matters. if ur actions dont harm another human...leave alone.
